Use ring to select different channels on labview
Yes, now I do have that info but if I use a different file to display through this program and if I don't know how many channels it has then how can I extract this information? I used index array to figure out how many channels it has but I am not able to show it in ring menu.
Message 11 of 21
(1,877 Views)
That is absolutely correct. In the other example i provided how to select the channel based on an enum ring.  youll need to change that to a text ring and use what udka has provided. Then also convert from dynamic data to a 2d array so that you can get the number of channels and youll probably want the names of the channel to write to the text ring, but up to you.
-Matt
Message 12 of 21
(1,877 Views)
-What is your file format?
-Does it contain number of channels present?
-You mentioned somewhere 2d data, can you give sample of it?
-As you mentioned 6 channels, how you found it is 6 channels?
-One of the dimensions of your 2d array is 6?
uday
Message 13 of 21
(1,874 Views)
Hey udka! My file is captured dat and yes it does have numbe of channels present in it. I found it is 6 channels by using index array through which I found that the dimensions is 6.
Message 14 of 21
(1,868 Views)
Matt are you talking about the example in post 3 or post 8. Also, once I get the number of channels how can use text ring to generate the names of channels. If I am not wrong, do you mean by using edit items option?
Message 15 of 21
(1,864 Views)
Yes i was referring to the example i posted in 8 and to change the values and names of the ring refer to udka's suggestion in post 10.
-Matt
Message 16 of 21
(1,856 Views)
But in the example provided by udka the input to the property node is string array but I have a 2D array. So, what should I connect to 2D array so that I can get the number of channels info and show it in text ring menu?
Message 17 of 21
(1,849 Views)
Sure if you spend some time the links provided in here: http://forums.ni.com/t5/LabVIEW/Use-ring-to-select-different-channels-on-labview/m-p/3329139/highlig...
uday
Message 18 of 21
(1,844 Views)
Well I spent some time looking at the tutorials but I was not able to find something similar to that. That's why i asked about it but I will spend some more time into it for sure now.
Message 19 of 21
(1,837 Views)
Yes it does.
"But in the example provided by udka the input to the property node is string array but I have a 2D array. So, what should I connect to 2D array so that I can get the number of channels info and show it in text ring menu?"
-If you carefully go through them there are some places you will get data types and arrays.
-After going through i am sure you will.
uday
Message 20 of 21
(1,831 Views)
