Use text file as input for a NI-USB
Hi i want to read a file to give as an input voltage for a ni-usb.i got a code where i choose between a constant value and a text.The constant value is ok but the text doesnt work when i try to measure with the multimeter.
(3,062 Views)
diro,
Could you provide an example text file that you're trying to use?
dK
(3,019 Views)
(3,006 Views)
In your text file VI, you are using the string "\n" as the end of file constant, but since it is in normal mode, it is a literal backslash and "n".  You want to make that constant have \codes display.  then edit it so it shows "\n" which at that point will be a linefeed character.
You may have more work to do with that because a typical  Spreadsheet string to Array is for 2-D arrays, not 1-D arrays, and the rest of the code makes it hard to determine if you are indexing out the value you want.
(2,979 Views)
I made some changes.Also I did make that constant have \codes display. I also tried to make the spreadsheet string to array a 1d array by using Initialize array.At path_1.vi i get to show only the first value of the text.And an the 1ni.vi it doesnt even appear the 1st value
(2,956 Views)
Here are cleaned up versions of 2 of your VI's.  It got rid of some Rube Goldberg constructs as well.
When working with indices, they should be I32 integers and not Doubles.
Don't call a numeric indicator "String" when it is a numeric.
I changed the handling of your file so that it treats like incoming string data as a 2-D string (which is what spreadsheet string to array creates) and then picks out the only column that exists in that array.
(2,929 Views)
