Use unsupported framegrabber
I am a newbie to LabVIEW and I would like to use a "non-supported"
framegrabber (http://www.silicon-software.com) under LabVIEW.
How much time and effort would it cost to develop a LabVIEW driver to
fully operate this framegrabber ?
The framegrabber manufacturer deliver an SDK which allow you through a
Dll to developp your own C/C++ application... would it help ?
Thanks in advance
Sebastien
(3,370 Views)
The DLL will definitely help. For DLL functions that take pretty
straightforward datatypes, you should look to build a simple subVI
wrapper containing an Call Library Function configured for the DLL
function. The inputs to the DLL can be constants or can be connected to
the VI connector pane to allow for programmatic access. Build an icon
and put in a description and s
ave it into a SiliconVision folder in the
user.lib folder. This last part will just give easier access to the
functions as they are written.
For complicated DLL functions that take complicated datatypes, you may
need to write a wrapper function in your own DLL to map between the
complex types and simple types. These do occur, but LV handles many
types, especially if you read the External Code manual and ask for help
on this forum.
As for the time involved, some functions will take ten minutes, and some
may take half a day or more, depending on if you manage to shoot
yourself in the foot with C pointers and types.
But seriously, the first thing to do is to read through the
documentation for the DLL and figure out how many functions you will
need and how many times you see the word struct or other more
complicated C datatype stuff. If you haven't got the time or skills,
but do have the money, you might want to look for an alliance member in
your area.
Greg McKaskle
(3,370 Views)
Thank you Greg for the answer,
Do you know where I can find some example to write my drivers ?
Merci !
Sebastien
Greg McKaskle wrote in message news:...
> and put in a description and save it into a SiliconVision folder in the
> on this forum.
> your area.
> Greg McKaskle
(3,370 Views)
There are some examples that ship with LV, but you will find many more
on devzone or labview zone if you search for Calling External Code.
Greg McKaskle
> Merci !
> Sebastien
>>on this forum.
>>your area.
>>Greg McKaskle
(3,370 Views)
