User authentication within a corporate network
Is there another way of authenticating a user rather than using "runas" command when calling "System exe" within LabVIEW? By authenticating, I mean, checking if a user typed valid windows login password.
When calling "runas", an application to be run needs to be specified. Therefore, there would be another application appearing upon successful password. However, the intention is to check the password only and not to open another app.I wonder is there another way of doing this? Is there a pre-developed LabVIEW library?
Thanks in advance
(3,850 Views)
Here is a simple .Net implementation.
(3,842 Views)
Thanks that is exactly what I am looking for
(3,812 Views)
If aptivo's response solved your problem, please mark the post as the solution and give Kudos where they are due.
aputman
(3,795 Views)
aptivo's, thanks for the help.  This has been an excellent solution to my problem.
Before, I close I wonder is there anyone else would be having a suggestion on how to implement without .net? I know I might sound a bit too fuzzy, I just would like to reduce dependency .net if possible.
(3,764 Views)
