User click any type of Boolean button to open file path and browse for file
Greetings,
I am very new in LabView Programming.
Referring to the attached image, I am wondering if there is a way to open file path when boolean button (switches or LEDs) is clicked.
Boolean button clicked -> the greyed out file path control is enabled  -> and user can click the browse button
if not, would please suggest a better way to do this?
H
(3,529 Views)
Accepted by topic author quadratini26
Hi nnhas,
Upon value change (event!) of the button you could call the FileDialog function…
I guess this is what you are talking about with "open file path"!? Otherwise use FileOpen to open a file when the user clicks on those switches…
Boolean button clicked -> the greyed out file path control is enabled  -> and user can click the browse button if not, would please suggest a better way to do this?
There is no "greyed out" filepath control in your image…
But you can use a property node to set the activation state of controls!
(3,500 Views)
