User interface with cRIO
I am new to cRIO. So bear with me if the query is basic.
In my application I have a real time plot of 7 channels ; real time gauges for 3 other parameters ; and a counter to update machine cycles once every 2 seconds; and  4 nos of user interaction buttons.
 I will develop the code in LV8.2.1 + LVRT + LVFPGA in the PC connected to the cRIO via Ethernet and download the compiled code to the cRIO.
Query is :
Now can I use the above PC linked to the Ethernet port of the cRIO and display the above user interface ? With all the above load on the display what kind of update rates can I expect to get ?
Thanks for your time.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(5,242 Views)
hi,
.For every proj in RT may contain host and target vis, you try  building   a Host vi to meet ur need,i.e use FPGA interface functions to build ur vi..u can get all the controlls and indicators in the FPGA read write control .
Still if u r not clear ,pls check with the examples
thanks&regards
Senthilnathan
(5,240 Views)
Hi Senthil,
Thanks for trying to help.
But frankly I just could not make out what you were trying to convey. You had mentioned about some examples. Any links ???
Raghunathan
Raghunathan
(5,233 Views)
hi
if u got ur RIO /fpga drivers installed ...search as follows
in labview>> help>>find examples>> select directory structure>>select crio folder...you will find examples....or type crio and search in that..
(5,221 Views)
