User-selectable Butterworth/Chebyshev/Elliptic filter
I'm currently putting just the Butterworth filter in my block diagram. But I'd like to add a function in the front panel letting the user pick whether to use Butterworth/Chebyshev/Elliptic filters. How may I do that? Thanks.
Also, I need to have a frequency waveform that goes into the filter. But what I currently have is the input voltage and the amplification. How may I get the frequency waveform? Thanks again.
(2,651 Views)
Hi Manson,
You could use a sequence and a proper property nodes, see the example attach. For the other question, i don't understand very well but, i think you need extract the value using a "value, property node".
Hope this help,
JFT
(2,651 Views)
