Kindly refer,
http://zone.ni.com/devzone/conceptd.nsf/webmain/BF9C43586430C32B86256BFB00528558?opendocument
http://search.ni.com/query.html?col=alldocs&qp=%2Bcontentformat%3Asoftwarelib&layout=SoftLib&qt=%2Bimaq+trigger+pulse
The pulse that the imaq board generates is not meant to drive motors. For that we have motion cards, refer, ni.com/motion
http://zone.ni.com/devzone/conceptd.nsf/webmain/66E6F4EE7E0848D686256A550060C436?opendocument
IMAQ Generate Pulse - This function allows you to generate a pulse from the TIO chips on the board. This functionality is only supported with the 1409 and the digital boards (1422, 1424, 1428). You can only drive at most two pulses at once. Driving pulses doesn't require events, unless you are triggering the pulse off o
f the Frame Start or Frame Done.
IMAQ Trigger Read - This function allows you to read the status of External Trigger lines or RTSI lines.
