Using 2 different timing parameters inside 1 loop
I have one loop with its "Wait Until Next ms Multiple" function. At each 5000 ms, this loop checks the condition of a boolean variable to decide if it's going to run a case structure.
My question is: now I want to add another condition to run that case structure. I want that it run at each 20000 ms independently of the boolean variable's condition. How can I inclued this second timing paramenter in my loop? What's the best way to do this?
Thanks!
Daniel
(3,204 Views)
Hi Daniel,
since 20s is a multiple of 5s, you can use the loop index with a "quotient & remainder" to check on every fourth loop-count. Then use a case structure independent of the boolean variable.
Greets, dave
Greets, Dave
(3,197 Views)
one way is to say if the current time since the start of the test - the start time of the test / 20000 has a remainder or your button is true and it has ben 5000 ms then to do your true case.
take a look at the attached vi
if you have any questions don't hesitate to ask
(3,195 Views)
Thanks a lot, guys!!
It worked just fine with the "quotient & remainder" function.
Daniel
(3,180 Views)
no problem just ask if you have any other questions
(3,176 Views)
