Using 2D image as a "constant" vs a file?
I want to programmatically display a series of JPG's on my front panel.  I see examples where you can read a JPG file from the hard drive and do just that.
But is there not a way to drag an image into a picture constant box, or something like that?  That way the image is built into the VI and when I deploy the application I don't have to worry about image files being present, or getting corrupted or deleted.
Paul
(2,965 Views)
Check out the Picture Ring control.
(2,963 Views)
Yes.Through picture Ring controls.You must copy a picture to the clipboard before you can import the picture into a ring control.Then Right-click the picture ring control or text and picture ring control and select Import 'Picture from Clipboard' from the shortcut menu.
Also go through this:-
http://www.ni.com/white-paper/3211/en
Thanks as kudos only:)
(2,954 Views)
Winning!
Thanks.
(2,941 Views)
(2,908 Views)
