Using Active X from labview to program the Agilent 16902A Logic Analysis System
I'm trying to Automate the 16902A agilent Logic Analyzer. I don't know if anyone has used it before but I've gone through the COM API for this application to find a method/property to set the Acquisition depth on this instrument. There is some XML script example to set the depth but I have no clue how to use it in the Labview flow.
(3,004 Views)
Hi Sreekar,
I have not worked with that device, but is it possible that Agilent has more information about how to access the software?  Maybe if you break the problem down more we can help.  Such a specific issue seems unlikely that anyone on the forums has the exact answer.
Brian K.
(2,981 Views)
