Using C+ Function "QSORT" in LV
Hi all,
I'm converting some C+ code to LabVIEW.
I want to use the C+ "QSORT" function as I cannot find an equivalent in LV.  Is there one?
Can I use the Code Interface Node?  I don't have a C compiler.  I don't know how to write a C file.
Here is a description of the QSORT function taken from the Using External Code in LV manual (p276):
QSort
void QSort(arrayp, n, elmtSize, compareProcP());
Purpose
Sorts an array of an arbitrary data type using the QuickSort algorithm. In addition to passing
the array you want to sort to this routine, you also pass a comparison procedure that this sort
routine then uses to compare elements in the array.
The comparison routine should return a number less than zero if
a is less than b, zero if a is
equal to b, and a number greater than zero if a is greater than b.
You should declare the comparison routine to have the following parameters and return type.
int32 compareProcP(UPtr a, UPtr b);
Parameters
Name Type Description
arrayp Uptr Pointer to an array of data.
n int32 Number of elements in the array you want to
sort.
elmtSize int32 Size in bytes of an array element.
compareProcP CompareProcPtr Comparison routine you want QSort to useto compare array elements. QSort passes
this routine the addresses of two elements
that it needs to compare.
(4,999 Views)
hi battler,
 why dont you make use of sort vi in array pallette...
thanks and regards,
srikrishnaNF
Srikrishna
(4,978 Views)
There is no generic quick-sort in LabVIEW - you would have to code your own implementation. 😞
@srikrishnaNF
The advantage of an equivalent to that Qsort routine is that it is possible to customize the order logic - in the Sort 1D Array function, you are restricted to sorting by ascending number or alphabetical, and if you are sorting an array of clusters, only the 1st element in the cluster is used for the sort.
(4,960 Views)
I found a couple of QUICK SORT LV implementations.
They appear to work for simple numeric arrays but I cannot get them to work for my application.  I'm trying to implement the Graham's (Hull) Algorithm (see here).
Attached are a couple of the implementations.  I got them from here and another place.
I'm trying to sort cluster array.  My Compare function compares 3 (not 2) array elements.  It appears to sort some of my array correctly but may be terminating early.  The attached implementations call only 2 instances of QSORT recursively.. do I need more?..
Message Edited by battler. on 05-22-2010 09:24 PM
(4,953 Views)
Custom sorting is very easy in LabVIEW.  Don't make it more difficult than it needs to be.
To sort by a group of keys, you need to build a new array with the keys at the beginning.  For example, for each old cluster element, build a new cluster that has key1, key2, key3, and old cluster.  Use 1-D sort array to sort the new cluster array, then loop and extract the original cluster from the new cluster.  Another approach is to just store the index of the original array, then use the sorted index list to create the new array.
1-D sort array will always sort clusters by the first element.  If the first elements match, it sorts by the second element, etc.  It will sort by all the existing elements if necessary.  Thus, it will sort by the multiple keys in your new cluster.
Bruce
Bruce Ammons
Ammons Engineering
(4,901 Views)
