Using CLI to communicate with Azure IoT Hub
I have been communicating with Azure System.exec.vi and CLI for Azure but I have hit a snag.
One command line i use is monitor-event. This is an infinity loop which I cannot seem to get out with programming. Only a physical ctrl-c will exit the loop. This of course also means loosing the data from the loop.
Does any one have a suggestion how to solve this?
(2,071 Views)
What is that command? normally Linux always has the solution to finish without control-C.
please set this as ANSWER or KUDO this post, if it help you.
(2,019 Views)
I am not sure what you are suggesting?
My programming skills is rather limited to LabVIEW at the moment.
I simply need a better solution to get out of the loop.
Soren 🙂
(1,996 Views)
I want to know the command you use, I may give you another command that not need ctrl-C
(1,990 Views)
One thing which might help you is something like this JKI wrapper, which should give you access to stdin and stdout, which I assume will allow you to communicate with the process:
https://www.youtube.com/watch?v=4F2-Ml71z78
___________________
Try to take over the world!
(1,976 Views)
The ctrl-c in cmd is BREAK. This does not work.
To solve the problem, I currently use cmd write to a txt file ( > output.txt) then I kill the cmd processes.
(1,962 Views)
