Using COM 2 twice !
I have a vi which successfully communicates with COM 2, and another vi which also successfully communicates with COM 2. I would like to run them both at the same time.
Can anyone tell me the best way to go about this please ?
(3,345 Views)
Why don't you make one vi which will communicate with COM2...and send/receive data to the two vis ?Smiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,331 Views)
Accepted by topic author Placebo
In general, I try to avoid simultaneously accessing the same hardware, but I understand it is possible:
http://digital.ni.com/public.nsf/allkb/6210E70E87FE4509862573A600697EBF
http://www.medicollector.com
(3,326 Views)
This is perfect, thank you
(3,317 Views)
