02-15-2007 07:35 AM
02-16-2007
05:59 PM
- last edited on
08-24-2026
04:26 PM
by
Content Cleaner
Hello Jim,
Actually, the two options you listed should execute in the same amount of time. While they appear slightly differently in LabVIEW, they will compile to the same code. So, at run-time there is no difference between the two. In fact, if you place a DAQmx Task Constant in your LabVIEW Block Diagram you can right-click and select Generate Code»Configuration and Example to automatically generate the associated NI-DAQmx sub-VIs.
For more information about the functionality of NI-DAQmx I would recommend that you check out our Getting Started With NI-DAQmx resource. I hope this information is helpful. Let me know if there's anything else I can do.
02-19-2007 07:27 AM
