Using DAQ 6009 to measure RF
Hello, I need some help please. I want to measure the Frequency comming from RFID reader (434 MHz) . therefore I am using DAQmx that  mesures about 1 KHz . so ANY idea how can I measure the Freq. of rfid ?
thanks in advance
(3,182 Views)
follow the link. It may help you..
http://zone.ni.com/wv/app/doc/p/id/wv-1938/upvisited/y
Nitz..
(Kudos are always welcome;))
(3,175 Views)
The specifications for the USB-6009 state that the maximum input frequency to the counter is 5 MHz.  Since this is much lower than the 434 MHz you want to measure you either need an external prescaler or a different counter.
Lynn
(3,158 Views)
