Using DAQmx to get temp through SC
I am trying to get my program to display a couple temperatures and I am failing hard.
I am still at a novice level in LabVIEW experience, but I know my way around it.
I would post the full .vi but there are a bunch of sub vi's and scripts that are needed to make it run.
NI-PCIe-6321 card
SCB-68A DAQ
DRSL-TC (Omega) Signal Conditioner (set to 60Hz Output, 0-10V, 300ms rate)
Type K Thermocouple
If at all possible, I would like to figure out how to configure DAQmx to accept 4-20mA, since my current signal conditioner puts out that.
(1,648 Views)
6321 is a voltage input DAQ, this means it cannot measure current. On the other hand, you can convert the current into voltage using an external load resistor.
Santhosh
Soliton Technologies
(1,621 Views)
That helps m moving forward in the long run, but what about getting correct outputs on the indicators through DAQmx with voltages?
(1,612 Views)
I was able to get the voltage to read, but I cannot get a clean graph to convert to.
Any help on how to do this would be much appreciated!
(1,590 Views)
