Using Digital I/O
I am using LabVIEW 7 to talk to the SC-2075 Signal conditioning board. When i use the write to digital line vi, i seem to only ever be able to control the digital input/output terminal 0.0. I wish to control all the different terminals using switches in my front panel. Is there a setting i must change to control the other digital input/output terminals or is there another way of controlling all the terminals seperately?
(2,844 Views)
The write to digital line VI has an input to specify the "line" - are you wiring to it?
(2,838 Views)
