Using Dll in PXI RT
Hi LabVIEW fellows...
I have made a simple Dll (Subtraction of two numbers) in MS Visual Studios 2008  and i am calling it in LabVIEW under host computer target. the Dll is working fine .
     Afterwards, I pasted the same Dll in C drive of the  PXI RT 8106 Controller (Pharlap OS) under ni-rt\Systems folder and made a similar VI under the Rt target and deployed it but VI is not working properly.(Only the Values are getting passed and output is not calculated)....
Do i have to make the DLL in some other way for RT targets or i need to install some extra toolkits?????
Rohit
(3,880 Views)
Accepted by topic author RP.87
Dlls far as I know are made for the windows and if I am wrong could not be used in PharlapOS
(3,833 Views)
You might wanna have a look at this
(3,787 Views)
First of all thanks for ur reply....
but i have already used this DLL Checker and i am getting message saying ur Dll is Bad. what shall i do???
(3,770 Views)
