Using FPGA's internal memory
Hi there,
I'm trying to find out, which amount of memory I can use with the read/write memory.vi. The help says 8K x16bit, but I guess that refers to the 1M gates type FPGAs. How much is available on the 3M gates type? I already took a look at the xilinx data sheet, but I wasn't able to match the block RAM sizes given there with the sizes given by LV's help.
Thanks for your help!
Oli
Message 1 of 1
(2,633 Views)
