Using General Polynomial Fit VI with waveform graph
Hello gurus ,
I would like to ask how to use General Polynomial Fit VI with waveform graph not GraphXY .
Waveform graph is giving me an array of values not X , Y i think , what should i do ?
Thanks in advance
(4,410 Views)
Accepted by topic author OmarTariq
Hi Omar,
i changed the shipped Labview Example to use the General Polynomial Fit VI with a waveform graph.
But why don't you want to use a X-Y-Graph?
Regards
DianaS
(4,393 Views)
Thankyou for your reply ,
I am not using Graph XY because i already implemented  the program and i don't want to change the basic logic of the program which means i don't want to change the graph to XY as its a vast , complex program .
Thanks once again for the solution
(4,386 Views)
