Using HP cards/cables with Labview
I've just purchased Labview, but my card/cables are the ones I've had from previous years from HP (used with vee). I've called NI and one of their technical support staff told me that I should contact HP (agilent) for instructions on how to do that... Agilent tells me that I should speak to NI... so I'm kind of confused. Is there step-by-step instructions for doing something like that? I'm using "HP10833B" cables and "82341C ISA High-Performance GPIB Interface Card".
Thanks!
(2,751 Views)
An interesting point might be who actually built the card you have. If I remember correctly, at one point HP was reselling cards manufactured by NI. A good first try might be to try NI's drivers for their cards from the same time period and see if they work.
More fundamentally though, does the current GPIB drivers still support the ISA cards?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,751 Views)
Najmeh,
You can actually use LabVIEW and NI-VISA to communicate with your Agilent board. From the Agilent webpage for the board you are using:
http://we.home.agilent.com/cgi-bin/bvpub/agilent/Product/cp_Product.jsp?OID=536880377&NAV_ID=-12363.536880377.00&LANGUAGE_CODE=eng&COUNTRY_CODE=ZZ&JPID=/find/82341c
Go to the Library Key Information >>Faqs and click to on "How do I configure Agilent I/O cards and converters to work with the National Instruments software?" This will direct you to a readme file that contains the information you want.(I'm doing Agilent tech job...):
ftp://ftp.agilent.com/pub/mpusup/pc/binfiles/iop/m0101/readme/trouble/niinfo.htm#Agilent_HW_with_NI_SW
For info, our website contains also relevant information:
http://digital.ni.com/pub
lic.nsf/websearch/E56D3D4866BE0A8A86256942006626F0?OpenDocument
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(2,751 Views)
