Using HTTPS and SSH from LabVIEW VIs
I am currently using custom VIs, built over the TCP/IP LabVIEW VIs, to access to a distant machine with the TELNET protocol, and to access a HTTP server with the HTTP protocol.
In a near future, I will have to use more secure protocols such as SSH and HTTPS, that my VIs will no longer support.
Does the NI Internet toolkit support SSH and HTTPS?
And if it doesn't, what are the solutions?
Using PuTTY with a command line for SSH is suggested by NI and I have already tested this successfully.
Have someone other solutions and an idea for using HTTPS?
I'm currently using LV 6.1.
(4,901 Views)
You could find other solutions on this forum thread : http://forums.ni.com/ni/board/message?board.id=170&message.id=77865&requireLogin=False
Isabelle
Ingénieur d'applications
National Instruments France
(4,880 Views)
