Using I2C waveform in DAQ-mx
Hi all,
I am working on I2C protocol and would like to test it using DAQ-mx on a PXI. I have created the digital I2C waveform. But I am confused on how to use it with DAQ-mx, like how to input the signal and how to get the output. I2C communication has two lines-SCL and SDA. Should it be given separately by creating two different tasks or can be given in a single task? Also, how can I read the acknowledgement from the Slave based on which further transmissions are dependent(i.e.) How to configure it to read acknowledgement at the HIgh-Z state? Can anyone please help me out?
Thanks for the help in advance.
(3,738 Views)
(3,673 Views)
