Using ICP 260A02 Triaxial Force Sensors with USB 9234
    I have a PCB make 260A02 Triaxial force sensor which requires a separate signal conditioning unit before its output can be analyzed in LABVIEW using the DAQ unit USB-6008.
I also have a NI USB 9234 unit. Can I attach the tri-axial sensor output directly to the 9234 unit for data acquisition (bypassing the signal conditioning unit). My concerns are
1. The 26A02 sensor requires a 24 V , 2mA constant current exitation. The 9234 unit provides the 2mA current excitation at 5 V. Will the sensor still work ?
2. Is it possible to provide a separate 24 stabilized power supply across the output terminals and make it work ?
Kindly advice about the feasibility of this implementation.
(3,508 Views)
You should be able to use the sensor with the 9234.  (The max exitation voltage is per 9234 spec 19V  and the PCBsensorSpec claims 20V , however it should run.)
For the 6008: you will need a current limiter for each channel (BF245 FET with 500Ohm for 2mA)   and a coupling capacitor (470nF to 2µF) for each input to cut off the 8-12V bias. Since the 6008 has a quite low input impedance (140k???) you might get into trouble with lower freq. signals
Message Edited by Henrik Volkers on 06-01-2010 11:39 AM
Greetings from Germany
Henrik
LV since v3.1
(3,461 Views)
PCB 260A02 Triaxial force sensor should work well with the USB-9234 or USB-4431 connected directly.    The PCB sensor requires 2 mA of excitation current which it provides when you enable ICP.
(3,344 Views)
