Using Internet tool kit how to communicate with 2 computers which are far apart and each computer is part of local network
I started using internet tool kit very recently.
I have an application as briefed below,
Computer 1 is connected to local network 1.
Computer 2 is connected to Remote network 2.
Network 1 and Remote network 2 are far apart and they are connected to internet.
It is required to open a Telnet session between computer 1 and 2 through internet.
How to achieve this?
Which are the functions to be used?
Where to enter Gateway  and Subnet mask addresses?
Can any body help me out.
Regards
SajK
(2,607 Views)
Have you looked at the shipping example called Telnet Line Client? I have had no problem using that to connect to telnet servers. I have not tried to create a server from the toolkit but doing so shouldn't be to different from the TCP/IP server examples in which you create a listener (Telnet Listen) and then do a Telnet Wait On Listener.
I don't understand your question about gateway and subnet. To establish a connection, you provide the telent port number (default of 23) and the IP or hostname. If you already have an Internet connection, your OS should already have a default gateway defined.
(2,599 Views)
