Using LABVIEW Is it possible to find Frequency response of a particular device
We have 6259 data acquisition card,Using LABVIEW how to find Frequency response of a particular device and How we configure the input from data acquisition card...? Please explain the procedure
Thank you.
(4,651 Views)
It should be possible to do it.
What type of device or frequency range are you trying to implement?  What precision do you need? (sampling rate, etc)
(4,624 Views)
I am trying to check the frequecny reponse of Servo motors.
Freq Range: 1-40 Hz
Sampling > 100 KSPS
I will get the feed back voltage from Servo motor that is used as ouput.
regards,
Y.Stalin
(4,597 Views)
Mr. Stalin:
Regarding your query, you can find the detailed tutorial on frequency response analysis via LabVIEW here
Hope this answers your query
Sanchit Juneja
Email: support.india@ni.com | Phone: 91-80-41190099
Learn at NI Developer Zone: http://www.ni.com/devzone
(4,564 Views)
AMMING Actually we are performing frequency reponse analysis for a motor. is it possible to write a program for the fra using microcontroller in embedded c. could you please suggest...
THANK YOU
(4,303 Views)
