01-15-2002 03:48 PM
01-21-2002 03:57 PM
01-23-2002 10:41 AM
01-23-2002 12:47 PM
LabVIEW, C'est LabVIEW
01-23-2002 01:33 PM
01-31-2002 12:51 PM
01-31-2002 10:36 PM
02-01-2002 09:01 AM
11-28-2005 07:51 PM - edited 11-28-2005 07:51 PM
I believe this is a related question. I am developing a LV application the uses TCP/IP to control up to 8 devices-under-test (DUT) at one time. They start and finish testing at arbitrary times relative to each other, and the IP addresses are not known until the DUT arrives. I have some question on what is the best way to manage the TCP/IP handles.
Presently, I have 8 Global IP addresses (one per testing site) that are updated as DUTs arrive and depart, and then whenever I need to communicate with a DUT I use TCP-Open, Write/Read, and TCP-Close. I do this Open/Write/Close each time there is a message to be sent to a DUT. This is basically working, but I notice that the OS (Windows XP or 2000) is running through local TCP/IP ports at a ferocious rate due to the TIME_WAIT behavior of Closed TCP/IP ports (It takes many minutes for a local port to become available again after being closed). If I am not careful, I can quickly exhaust the pool of OS ports by using tight polling loops or other very quick DUT accesses. I have tried not to do that in order to avoid running out of handles, but it is still very wasteful of ports.
While it is working, I feel so dirty burning through these handles like this since they appear to be a precious resource. I really cannot easily merge multiple Read/Writes into a single Open/Close since there are dozens of otherwise unrelated tests that communicate with the DUT as a part of their functionality. The tests are even in different subVI's that are accessed via a vi-server, and only one is loaded at a time.
I thought that a cute idea would be to cache the handles in Globals, and wrap the Open to use the cache if valid, but reading this thread is making me think it is a lot of effort -- I believe I would need to keep a VI running as a "IP Connection Server" at all times and use some form of messaging to get it to Open/Close TCP connections as needed. Since the DUTs arrive at aribitrary times, and with random IP addresses, I cannot establish all the TCP handles ahead of time -- they would need to be created dynamically. It is much more difficult than simply keeping the Connection IDs in global variables -- the VI that Opened them must not be allowed to terminate.
So... I am curious...... is it really that bad to Open/Close as frequently as I am doing it? Does it make me a bad person? I understand it is inefficient use of time, but the simplicity it brings to the structure seems huge, and the DUT is very slow anyway. And if it is bad, are they any more recent thoughts on alternatives? Do VISA handles behave the same way as TCP handles (ie. auto-close themselves upon exit of the VI that Opened them) ?
Message Edited by Mike Seibel on 11-28-2005 07:55 PM
Message Edited by Mike Seibel on 11-28-2005 08:00 PM
Message Edited by Mike Seibel on 11-28-2005 08:01 PM
