Using LabView for ESL(Electronic System Level) design
With respect to ESL design, is LV capable of the following:
modeling concurrency
non-functional modeling and estimation(power, area)
performance estimation (throughput, latency)
code conversion to C and Verilog
How do you compare it with SystemC for ESL design?
(4,098 Views)
You should always spell out acronyms to avoid confusion. ESL has many meanings! 😮
(4,089 Views)
Electronic System Level, sorry 🙂
(4,081 Views)
I'm guessing you are experienced in ESL and SystemC, but not in LabVIEW.  Most of us are experienced in LabVIEW and have possibly never heard of SystemC or ESL.  In particular, I certainly don't know what the objective is for ESL, whether it is a modelling system, a simulation system, a way to develop code that runs on real hardware, or what.
If I'm right and you are an ESL expert, my guess is that you can fairly quickly get a feel for the "idea" and abilities of LabVIEW and will be in a much better position, certainly, than I to answer your question.  In particular, the videos under LabVIEW for Students on the upper right of the first page of the LabVIEW Forums are a quick and easy way to get some of the "flavor" of LabVIEW (you can probably skip some of the videos, but spend some time with the later ones).
Bob Schor
(4,011 Views)
Hi Bob,
You are right. Thanks for the reply 🙂
(3,996 Views)
