Using Labview 5.1 to run SSR board and modules
I am having trouble programming Labview 5.1 to run SSR modules on a SSR series backplane. Running Windows NT4, PCI-5042E multifunction I/O board. Labview will talk to the 5B board and modules. But I have not be able to use the SSR's. What am I missing?
(3,022 Views)
Greetings,
What behavior are you seeing? What behavior are you expecting? Which VIs are you using in LabVIEW to control the SSR modules? Can you control the SSR modules from your DAQ board's test panel in Measurement & Automation Explorer?
Spencer S.
(3,022 Views)
Thanks for your reply. Sorry didn't get back to you earlier. But you made me stop and think about the behavior. And I released that I hadn't put a module in the board nor power to it. Let me play with it some more and see what happens. Thanks.
(3,022 Views)
