Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Using Labview 6.1, I have problem when I try to build my application.
gege
Member
09-01-2003
02:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to build up an application into an executable. I have already succeeded in building such an executable but with the vi I want to build in an executable this time, I just crate a labview library. What's happening ?
0
Kudos
Message
1
of 2
(2,331 Views)
Reply
Re: Using Labview 6.1, I have problem when I try to build my application.
Evan
Active Participant
09-02-2003
08:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Are you using the application builder to build the exe or are you selecting save with options>>application distribution?
To build an exe you must select tools>>Build Appliction or Shared Library (DLL). To create an llb, you select save with options.
0
Kudos
Message
2
of 2
(2,331 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
