Using Labview 6.1 on Linux, the 'Current VI's Path' function returns an incorrect and unuseable path.
'Current VI's Path' is returning my home director rather than the vi path and it has a back slash '/' at the end which means I can not append to it. Is this a bug?
(3,127 Views)
Hi Jack,
I emailed you the my suggestions below
"I tried running LabVIEW 6.1 on a Linux machine here running red hat 7.2 and I couldnt reproduce you issue. I got the full pathname '/home/login_name/untitled1.vi. I even tried LabVIEW 7 and that worked fine too. This maybe a silly question but I just want to make sure we have
everything covered. Did you stretch the path indicator so that you are seeing the complete path?
If you are just concerned about the '/', then what you can do is convert the path to string, remove the '/' from the string and finally convert the string back to path.
These VIs are located at Functions >> Strings >> String/Array/Path
Conversion.
Good luck
Feroz P
(3,127 Views)
