04-30-2007 03:26 PM
05-02-2007 09:31 AM - edited 05-02-2007 09:31 AM
This is going to depend a lot on the sensor and unfortunately I have no experience with magnetic sensors. I can point you to a couple resources though. Most of the magnetic sensors I have found info on generate a TTL pulse that you then measure the frequency of. Here are a couple links on that -
Using a Magnetic Encoder in an Anti-Lock Braking Application
I have a magnetic pick up sensor
How do I measure RPM from a magnetic pick up?
If you use a sensor that generates a TTL signal, you'll want to use the counters on your 6221 to measure the frequency of the signal. If you wanted to keep the SCXI system in the loop, you'd probably want to use the feedthrough module.
Hope this helps,
Andrew S
Message Edited by stilly32 on 05-02-2007 09:31 AM
05-02-2007 09:48 AM
Thanks for that input!
It would likely be a TTL signal, although reluctance is possible (if that's the case then it would need internal processing to filter the reluctor wave to a square TTL style wave).
I do have the 1180 feedthrough panel and a terminal block for the front of it. Am I going to be able to connect this sensor (actually there will be eight total sensors on eight separate locations) directly to it if it's a 0-5v application?
And most importantly, will this be considered an analog input signal or a digital one? The 6221 has 16 analog ins... But only shows 2 counter/timers!
I'm thinking I'm going to need that 1126 module to do eight locations, correct?
05-04-2007 08:26 AM
With 8 signals, the 1126 is going to be fine - it can read a square wave, so you're TTL signal will work.
Andrew S
Continued here
