Using Labview VI as a Matlab function.
I'm trying to use Labview VIs in a Matlab script. The VI should act as a function with input and output arguments. Tried to compile the VI to a .DLL file, however was unable to read the file using Matlab.
Any advise?
(2,949 Views)
What errors did you get? Can you access the DLL from some other application that uses DLLs (i.e. Excel)? Try creating a very simple DLL that just adds two numbers together, does that work?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,933 Views)
