Using Labview's System Exec.vi, is there any way to send multiple standard inputs to the same executeable console? Or is there a way using Labview to target the window for the executeable and send commands to it at will?
One suggestion is to write a batch (.bat) file that will call your executable. The batch file can contain all the standard inputs necessary to run the executable. Then, in LabVIEW, you can call the .bat file using the System Exec.vi.
As far as your second question, there is no slick way to do this LabVIEW. You would probably have to call Window API functions using the Call Library Function utility. There is a set of VI's that call some of the standard API functions but I don't think they have what you want.
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&74DDE683A1AFF6988625683A000C0D73&cat=034E59A8530E09DF862568900018707A
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,776 Views)
