Using Labview to control an infrared heater
Hello all.
I am using LabView and SCB-68 to control an infrared heater. The VI I'm working on allows you to set the target temperature, compares it with the actual temperature (thermocouple to SCB-68) and sends out voltage. However, how do I get to VI to hold the temperature when it reaches the set temperature for a set amount of time?
Thanks a lot.
http://www.researchinc.com/control_930_935.asp
^^ That's the controller for the infrared heater.
Attached is the VI I currently have.
Thanks for all responses.
Message Edited by mjagani on 06-30-2008 09:34 PM
(2,924 Views)
Let me know if you guys need any more information.
(2,907 Views)
You should continue the discussion in this thread
(2,889 Views)
