Using Labview to make a custom wave for daq assistant to output
Hey there, I have a table of x values which I have made into a wave form.
I was curious as to whether this wave form could be outputted by my Ni Daq via Daq assistant, or is there an alternative method for outputting a table of values via a daq card?
Thank you
Message 1 of 9
(3,670 Views)
Okay, I've more found the problem to be that I can't get the daq assistant to show options like it is here
http://forums.ni.com/ni/attachments/ni/170/502252/1/blockdia.jpg
Anyone have any suggestions please?
Message 2 of 9
(3,652 Views)
That image shows a Simulate Signal function and not a table so I don't understand your question.
Message 3 of 9
(3,644 Views)
Okay, two separate questions then, sorry
How do I get a series of x values made into an output for the daq
The second question is how did this person get all the options for the daq assistant/the daq output?
http://imgur.com/TkzcPIS
That's what I have, and I'm unsure how to put wire inputs into it
Message 4 of 9
(3,634 Views)
Please don't attach images from some odd third party site.
It doesn't look like you've configured the assistant or something is corrupt with it.
A table is a 2D string array so you'll have to use the Index Array function to get the specific column and then convert to dbl. Does it also contain timing information?
Message 5 of 9
(3,626 Views)
Sorry about the image, just wanted to show my set up (I'm very my a newbie to labview)
Is there anyway to configure or uncorrupt the daq assistant?
I have a column for the time and a column for the displacement
Thank you for this help by the way
Message 6 of 9
(3,621 Views)
Accepted by topic author TWCRN
Message 7 of 9
(3,610 Views)
Thank you
Message 8 of 9
(3,595 Views)
Works perfectly. Thank you very much for your help
Message 9 of 9
(3,599 Views)
