Using Labview to process a video stream and detect a color range
Since the dimensions are being transmitted in your header, it seems like you would be able to assemble a 2D array by "breaking" your 1D array into rows as defined by the width property in the header.  For example, if your image is 320x240, you would make a new row after every 320 elements in your 1D array.
Message 11 of 13
(1,179 Views)
Message 12 of 13
(1,159 Views)
Hi londonew
can you please post the full VI after you modified it and after you added the solution?
Message 13 of 13
(552 Views)
