Using MATLAB Plugin to handle 'Struct' variables
I am using the Matlab Script Node in LabVIEW to communicate with a MATLAB function.
One of the MATLAB functions that I am using requires an input in the 'Struct' data type. However, using the input terminals on the Matlab Script node I can only select from Real, Complex, 1D Array, 2D Array, Path or String.
I have installed the MATLAB DataPlugin from National Instruments. On the webpage, it states that STRUCT data is supported for Import functions.
However, using the 'Help' function for the same plugin in LabVIEW, it states that 'Struct Datatypes are currently not supported.'
Can anyone advise if it is possible to use 'Struct' variables as input to a Matlab Script Node, and how I should approach this.
(2,823 Views)
What version of LabVIEW are you using?
(2,721 Views)
