Using MS words word art on front panel
Recently i was working with some software which had MS word's word art (Images)used on front panel ?. The front panel looked nice, decorative and colorful. But i am not sure how good is it to use excessive images on the front panel.
(2,383 Views)
Is there a question?
If you're worried about using images on the FP, it depends - heavyweight images (I don't think Word's qualify) make your VI bigger, because they're stored in it and I think any image you use that has controls hovering over it causes redraws of the display more often (which does cost in performance). That said, I did use large images in VIs, with controls over them, with no problem, so the question is what you want the application to do. Try using the images. If you don't see any performance issues, you're cool.
___________________
Try to take over the world!
(2,381 Views)
