Using Matlab Code in Labview
I want to use the Matlab Code that is performing an Image Processing task in Labview. I have read this page http://www.ni.com/labview/mathscript/  But i still have an issue that the code has too many function (not build in functions) files that were written in Matlab separately to reduce the code. Now if i have to add all the code into the MathScript it will make the code too lengthy. Here is the list of functions present so you can understand the situation.
Kindly guide me how to run the matlab code in Labview while keeping the function simple as possible.
(4,051 Views)
See here
(4,042 Views)
