Using Multiple Daq
In terms of a custom calibration,  perhaps what you want is a custom scale?
The DAQmx VI that creates a channel allows you to choose a custom scale (as created, for example, using MAX) but I don't know how popular this option is - you can alternatively do the equivalent calculation manually in LabVIEW starting from voltage.
If you look at your previous calibrations, I imagine they will describe the relation between for example force and voltage in the form of a linear equation. Implementing this is LabVIEW should only require two numeric constants, an add/subtract and a multiply node.
If you have a nonlinear relationship, you could implement interpolation between known data points as an alternative (but this doesn't sound like what you've described)
Message 11 of 12
(1,000 Views)
Thanks! yes it is linear, I will try to do that and also try to do that with custom scale.
Message 12 of 12
(995 Views)
