Using .NET FolderBrowseDialog in LabVIEW
I want to browse for folder, so I call .NET FolderBrowseDialog.ShowDialog method. But there is no tree view in a opened dialog - only buttons <ok>, <cancel>... Does anyone know what's wrong?
(5,165 Views)
Please show us the code (uploading it would be better).
(5,151 Views)
If you just want to browse for a folder, why not use the build in LabVIEW primitive instead of a .NET call?
(5,139 Views)
Accepted by topic author pav_
Hi pav,
have you read this thread on exactly the same problem?
(5,133 Views)
Solved! Thanks a lot!
(5,115 Views)
It would help if you indicated what the solution was, so that others who run into this and find this thread from a search (assuming they bother to search) will at least know of a potential solution.
(5,110 Views)
This solution is the most suitable to me.
(5,102 Views)
