05-05-2008 08:59 PM
05-06-2008 12:25 PM
05-06-2008 01:28 PM
05-19-2008 01:42 PM
05-20-2008 12:36 PM
Hi Chris,
If you are getting unexpected outcomes, the data upstream of the comparison must be different than expected. Have you tried probing both the data coming out of the feedback node and going into the feedback node to ensure that you are getting the expected values for both? It seems like noise might be causing something such as this. Does it consistently switch between true and false on every iteration or does it just go to false once every few iterations or so. It may be helpful to take multiple samples and average them together before doing the comparison so that some of the higher frequency noise is not as noticeable.
