Using PCI-6503 in Traditional DAQ and LV2012 need an example of being in a particular event and if there is not an input from a particular switch then fail the test
I AM using a PCI-6503 in Traditional DAQ and LV2012 need an example of being in a particular event and if there is not an input from a particular switch then fail the test
(2,222 Views)
You can use a state machine with an event structure and inside of it you can create a condition that if there is not an input from a particular switch for a determined amount of time, you can send a message indicating that the test failed.
(2,180 Views)
