Using PCI 7830 in LabVIEW 2017 + 2018
Hi
It is not easily possible to use older FPGA Boards with LV2017 or 2018 because there seems to be no RIO drivers for this boards anymore. Is there a way I can use this boards with LV2017+ or do I have to dump working FPGA boards.
Regards, harald.
(3,138 Views)
Hi HarrySa,
According to this article PCI-7830 is no longer supported in latest versions of NI R Series Multifunction RIO Device Drivers (2017 and 2018).
You can stick to version 16 and use it with LabVIEW 2016 as well.
Regards
(3,105 Views)
Hi HarrySa
Unfortunately your module is not compatible with the LV2017 or LV2018, here's a link with some important information about the drivers, and the NI R Series Modules.
But if you want to use your module you can get an older version of LV like 2015 or 2016.
http://www.ni.com/pdf/manuals/375024f.html#install
Best Regards
(3,091 Views)
