Using Parallel Port as digital input
I want to use a parallel port as an input to start off a program and have been looking at the Parallel Port Read example inthe ni examples. I am having a little difficulty understanding it, I suppose because it reads and writes. I would like the parallel port vi to give a boolean output which plugs into the selector terminal of a case structure and when there is a state change it runs the loop. Could anyone explain how I modify the example. Thanks
(3,151 Views)
If i've correctly understand what you want, you only want to read a sigle bit from the parallel port. Well, if you simply wanna do that... you don't have to do anything to the example. He's already doing that. If the "write update" it's "true" reads and write's the parallel port. If "false", it only reads the current value.
You should remove the while loop so that you only read the parallel port once.
Jorge Amaral
Software developer
www.mcm-electronics.com
PORTUGAL
(3,135 Views)
