Using RTSI With the DAQ Assistant?
Hello, I am trying to synchronize 3 PCI-6052E cards via RTSI using LABView and the DAQ Assistant VI. I have set one card's (the master's) clock source as "Internal", and the other two to "External" and "RTSI0", however this doesn't work. I hit "Run" and nothing happens, and I have to use the Abort button to stop execution. It works great if I don't specify any sort of triggering options, however I need the cards to be synchronized. I have an RTSI cable installed, and it is shown in MAX also.
Do I need to set this up under the "trigger" tab instead? Any help would be GREATLY appreciated! Thanks!
(3,272 Views)
I have not used DAQ Assistant before. But maybe you can look under Help/Find Examples/Hardware Input and Output/DAQmx/Synchronization/Multi-Device/Muti-Device Synch-Shared Timebase-Finite(or Cont) Acqusition.vi.
The examples demonstrate how to acquire a finite (or continous) amount of data (Waveform) using the DAQ device's internal clock. It also shows how to share a timebase between two devices using RTSI.
Hope this helps,
Dan
(3,272 Views)
The assistant won't allow you to synchronize multiple boards. Dan's suggestion is the best to use the existing example.
Stuart G
(3,272 Views)
