Using Replace Array Subset (PXI-7813R)
Hi All,
Thanks for taking the time to read this post.
I have attached a picture of part of a VI I am currently working on.
I am having a problem with the Replace Array Subset function in the middle frame on the flat sequence structure. I initialise a 32 bit array of Booleans (all set to true) in the first frame of the flat sequence structure. I would like to replace the elements of this array with the values FPGA I/O probe "data_out" on the negative edge of the clock. This occurs in the for loop. Each time a bit is replaced in the array the previous replaced bit is set back to the initialised value from the first frame of the flat sequence structure. Is there a way to stop the replaced bits being reset to their initialised values?
Keep in mind this is for a FPGA target.
Michael.
(3,723 Views)
You're using the original array each time. If you want to use the modified array you should use a shift register to pass the array through the loop instead of tunnels.
___________________
Try to take over the world!
(3,697 Views)
Hi tst,
Thanks for the quick reply, it was most helpful : )
Michael.
(3,689 Views)
