11-30-2022 12:31 PM
My first attempt to use Runge Kutta failed miserably, and I don't know why. Here are front panel and block diagram:
I do not get any output. When I put a break point on the Times wire, it says Not Executed, and does not draw any graph.
What mistake am I making.
Girish
Solved! Go to Solution.
11-30-2022 12:52 PM
Hi girish,
You only attach images of code. We cannot debug/edit/run images in LabVIEW!
Mind to attach your VI with all used data set as default in those controls?
Did you check the error output of the ODE function?
11-30-2022 01:03 PM
Here is the VI.
11-30-2022 01:14 PM - edited 11-30-2022 01:14 PM
11-30-2022 01:22 PM
Deep.
Thank you.
Girish
